[Arduino source code for KC868-A16S]-05 LAN8720_UDP
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   A16S_LAN8720_UDP.zip (Size: 1.1 KB / Downloads: 614)
