KC868-A32M configure yaml for ESPhome
.txt   HA_A32M.txt (Size: 6.07 KB / Downloads: 558)
  platform: ESP32
  board: esp32dev
# Example configuration entry
  - id: bus_a
    sda: 4
    scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
pcf8574:
    i2c_id: bus_a
    address: 0x23
    i2c_id: bus_a
    address: 0x24
  - id: 'pcf8574_hub_out_3'  # for output channel 17-24
    i2c_id: bus_a
    address: 0x25
  - id: 'pcf8574_hub_out_4'  # for output channel 25-32
    i2c_id: bus_a
    address: 0x26
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_3
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_4
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
  - platform: adc
    pin: 34
    update_interval: 10s
    attenuation: 11db
  - platform: adc
    pin: 35
    attenuation: 11db
  - platform: adc
    pin: 39
    attenuation: 11db
  - platform: adc
    pin: 36
    attenuation: 11db
Should this config work for kc868-a32 as well? I've copy/pasted the below (and added manual IP address) but nothing is happening (no click)
I've just noticed I was sent Rev 1.2 instead 1.3  - Would that be a problem??
I think this is the interesting part:
[08:55:45][C][pcf8574:021]: PCF8574:
[08:55:45][C][pcf8574:022]:  Address: 0x21
[08:55:45][C][pcf8574:023]:  Is PCF8575: NO
[08:55:45][C][pcf8574:022]:  Address: 0x22
[08:55:45][C][pcf8574:022]:  Address: 0x25
[08:55:45][C][pcf8574:022]:  Address: 0x26
[08:55:45][E][pcf8574:025]: Communication with PCF8574 failed
.txt   logs_kc868-a32_logs.txt (Size: 8.26 KB / Downloads: 435)
this for A32M, if you want to use for A32, here is link:
https://www.kincony.com/forum/showthread.php?tid=1772
Nice! Thank you!
Thanks for this. Is there example esphome configuration for RS485 modbus master on KC868-A32M?
we have this sample for other kincony ESP32 board, but as same as KC868-A32M, here is video tour:
https://youtu.be/xmBWzVGpggo
https://youtu.be/xEvOK3R12kc
