KC868-M16-ESPHome.txt (Size: 7.98 KB / Downloads: 639)
esp32:
board: esp32dev
framework:
type: arduino
encryption:
key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
manual_ip:
static_ip: 192.168.1.186
gateway: 192.168.1.1
subnet: 255.255.255.0
cd74hc4067:
- id: cd74hc4067_1
pin_s0: 32
pin_s1: 33
pin_s2: 13
pin_s3: 16
- platform: adc
pin: 35
update_interval: never
attenuation: 11db
- platform: adc
pin: 36
update_interval: 15s
attenuation: 11db
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 39
attenuation: 11db
- platform: cd74hc4067
sensor: adc35
update_interval: 5s
number: 1
sensor: adc35
update_interval: 5s
number: 2
sensor: adc35
update_interval: 5s
number: 3
sensor: adc35
update_interval: 5s
number: 4
sensor: adc35
update_interval: 5s
number: 5
sensor: adc35
update_interval: 5s
number: 6
sensor: adc35
update_interval: 5s
number: 7
sensor: adc35
update_interval: 5s
number: 8
sensor: adc35
update_interval: 5s
number: 9
sensor: adc35
update_interval: 5s
number: 10
sensor: adc35
update_interval: 5s
number: 11
sensor: adc35
update_interval: 5s
number: 12
sensor: adc35
update_interval: 5s
number: 13
sensor: adc35
update_interval: 5s
number: 14
sensor: adc35
update_interval: 5s
number: 15
sensor: adc35
update_interval: 5s
- platform: ct_clamp
sensor: ai1
name: "Measured Current-1"
update_interval: 5s
filters:
- calibrate_linear:
# Measured value of 0 maps to 0A
- 0.0034 -> 0
# Known load: 4.0A
# Value shown in logs: 0.1333A
- 0.31749 -> 8.95608
- platform: template
lambda: return id(Measured_Current_1).state * 220;
device_class: power
unit_of_measurement: 'W'
update_interval: 5s
- platform: total_daily_energy
name: "Total Daily Energy1"
power_id: power1
filters:
- multiply: 0.001
unit_of_measurement: kWh
accuracy_decimals: 3
icon: mdi:clock-alert
device_class: energy
sensor: ai2
name: "Measured Current-2"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai3
name: "Measured Current-3"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai4
name: "Measured Current-4"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai5
name: "Measured Current-5"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai6
name: "Measured Current-6"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai7
name: "Measured Current-7"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai8
name: "Measured Current-8"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai9
name: "Measured Current-9"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai10
name: "Measured Current-10"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai11
name: "Measured Current-11"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai12
name: "Measured Current-12"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai13
name: "Measured Current-13"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai14
name: "Measured Current-14"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai15
name: "Measured Current-15"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai16
name: "Measured Current-16"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
time:
- platform: sntp
