access control panel by wiegand protocol configure yaml for ESPhome
here is demo config file for access control panel. control relay2 or relay3 by different finger or IC card or INPUT NUMBER by touch panel.
.txt   HA_A32_finger_wiegand26_tag.txt (Size: 12.93 KB / Downloads: 1,655)
Hi.
Can we use A16 board gpio for wiegand??
you can try, i am not tested. because these two gpio port have pull-up resistance.
can i use this with my lc868-a2 and please share the code
sure, any kincony ESP32 board with free GPIOs, can work for wiegand panel, just config by ESPHome.
can you please refer me to any tutorial of how i can do that
Sorry i'm still new
here is video tour about wiegand work with ESPHome: https://youtu.be/v-Vs4NbJy5k
please help me with the setup. I don't know what to do anymore.
I bought a device with wiegand26/36. I have it set to 26.
The manufacturer has assured me that the fingerprint tag is also sent via wiegand.
https://www.aliexpress.com/item/10050067...1802rCmbOz
Model: TF109S-EM-W
I have set the fingerprint for ID:002 according to the instructions. The unlock works but I don't see any unlock log in the esphome log. The lock physically unlocks.
Communication when entering the code works normally in esphome.
Any advice?
esphome yaml:
# Example configuration entry
wiegand:
- id: mykeypad
d0: GPIO15
d1: GPIO2
on_key:
- lambda: ESP_LOGI("KEY", "received key %d", x);
on_tag:
then:
- lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
- if:
condition:
lambda: |-
return x=="2";
then:
switch.toggle: test_output1
- if:
condition:
lambda: |-
return x=="02";
then:
- if:
condition:
lambda: |-
return x=="002";
then:
- if:
condition:
lambda: |-
return x=="0002";
then:
- if:
condition:
lambda: |-
return x=="00002";
then:
- if:
condition:
lambda: |-
return x=="000002";
then:
on_raw:
- lambda: |-
std:Confusedtring bits_str = "";
for (int i = bits - 1; i >= 0; i--) {
bits_str += ((value >> i) & 1) ? '1' : '0';
ESP_LOGI("RAW", "received raw %d bits, value %llx, bits: %s", bits, value, bits_str.c_str());
# on_raw:
# - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
key_collector:
- id: pincode_reader
source_id: mykeypad
min_length: 3
max_length: 3
end_keys: "#"
end_key_required: true
back_keys: "*"
clear_keys: "C"
# allowed_keys: "0123456789"
timeout: 5s
on_progress:
- logger.log:
format: "input progress: '%s', started by '%c'"
args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
on_result:
- logger.log:
format: "input result: '%s', started by '%c', ended by '%c'"
args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
- if:
condition:
lambda: |-
return x=="101";
then:
- if:
condition:
lambda: |-
return x=="102";
then:
on_timeout:
- logger.log:
format: "input timeout: '%s', started by '%c'"
I have set the fingerprint for ID 002 according to the instructions. The unlock works but I don't see any unlock log in the esphome log. The lock physically unlocks.
Any advice?
.txt   fingerprint_config.txt (Size: 3.08 KB / Downloads: 473)
sorry, i am not used this access panel, you can contact with supplier's technical support.
