Sample code for SIM800L and schematics
Hello everyone!
I would like to kinldy ask for some help with the KC868-A2. I am unable to communicate with the SIM800L module. I have tried to use the example code for KC868-A8S sms-relay and adapt it but it didn't work.
I have changed the Serial2 pins in "HardwareSerial.cpp" to RX2 34 and TX2 13.
Could you provide me with an Arduino source code for the KC868-A2 with the SIM800L module?
Thank you Blush
your TXD,RXD define error. here is config file for A2 and demo source code, this code can monitor GSM module's data,it's useful.
.zip   KC868-A2-AT-debug.zip (Size: 303 bytes / Downloads: 782)
Okay, thank you for the response. I have tried changing the "HardwareSerial.cpp" to RX2 13 and TX2 34 like you suggested. I couldn't get a communication going with your debug code. Also I looked at your pinout definition in LINK_ KC838-A2_pinout and it showed the following:
Quote:Relay1:15
Relay2:2
DS18B20/DHT11/DHT21/LED strip -1: 33
DS18B20/DHT11/DHT21/LED strip -2: 14
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
Looking at the schematics LINK_KC868_A2_schematic the GSM_RX is connected to I34 and the GSM_TX is connected to IO13. I think here lies the problem: I34 is an input only, and the GSM_RX is an input as well.
What I did to make the communication work:
In "HardwareSerial.cpp" : RX2 34 and TX2 13
I had to rewire the gsm module physically. In Header 5 (P4) I switched GSM_RX and GSM_TX
AT
OK
ATI
SIM800 R14.18
OK
Then it worked. With your configuration it did not work for me. I think it is because pin 34 can't work as a TX pin, as it is an input pin only.
That took a while... Tell me what you think Smile
just RXD and TXD by ESP32 or by SIM800L, TXD->RXD, RXD->TXD.
if sometimes can't work, just exchange the pin define will be ok.
(05-12-2023, 12:25 AM)admin Wrote: just RXD and TXD by ESP32 or by SIM800L, TXD->RXD, RXD->TXD.
From the ESP32-WROOM32E manual, pin 34 is type I=input, so it cannot be used for TX as I understand.
Name       No.       Type       Function
IO34        6         I           GPIO34, ADC1_CH6, RTC_GPIO4
Is there a way to switch the RXD and TXD pins on the SIM800L module with AT commands?
Is there a way to switch the RXD and TXD pins on the SIM800L module with AT commands? No, it's fixed.
Do you have a specification for the IIC connector? I cannot find a jumper calble that fits.
it's 2.54mm connector, very commonly used.
(05-11-2023, 07:05 PM)ebelingtec Wrote: Okay, thank you for the response. I have tried changing the "HardwareSerial.cpp" to RX2 13 and TX2 34 like you suggested. I couldn't get a communication going with your debug code. Also I looked at your pinout definition in LINK_ KC838-A2_pinout and it showed the following:
Quote:Relay1:15
Relay2:2
#define ETH_ADDR        0
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
AT
OK
ATI
SIM800 R14.18
OK
I think i have the same problem, i can receive information for the A7600E but i can't send now i use IO13 for RX and IO34
Can you says my what wiring you have make and what IO have you choose for now it's working ?
Thanks
Hello Anthonio,
you cannot make it work by changing the pins ins "HardwareSerial.cpp" only. You need to get wires and physically reconnect (see picture):
