Threads: 1
Hello, please could you list mfr. part numbers compatible screw-in terminal blocks replacement to replace the plug-in ones? 6x 1x9P + 2x 1x5P for digital inputs, 2x 1x9P for analog outputs 0-10VDC and 2x 1x9P + 2x 1x5P for AI and serial.
Threads: 1,473
just 2.54mm screw-in terminal blocks. do you have already bought KC868-AIO? or ready to buy?
Threads: 1
But the terminal blocks are pluggable that means each terminal block consist of two parts (first solder on the board and second- with terminals - plugged in). Each brand use different systems to connect (plug) those two parts and in most cases they are not interchangeable from different brands. I want to replace only the pluggable part - instead of plug-in I want to use screw-in ones. I already have KC868-AIO.
Threads: 1,473
we can upload screw-in terminal product to our aliexpress online store next week. then leave link at here.
Threads: 1,473
are you in EU? tomorrow we upload to our online shop, sometimes aliexpress have some limit.
