Threads: 1,204
not need add others, just let your 10pcs of E16S board all connect to router by network cable in local network.
Threads: 1,204
08-01-2024, 12:46 AM
(This post was last modified: 08-01-2024, 12:46 AM by admin.)
How can I toggle E16S relays from digital inputs on different E16S boards? There are two solution:
A. download KCS firmware, then create IFTTT command, let controller A's digital input trigger controller B's Relay by network custom protocol or RS485 command. if you also want use home assistant, let KC868-E16S integrate to home assistant by MQTT.
B. let your all controller integrate to Node-Red by MQTT. Then you can config any controller's INPUT trigger any controller's OUTPUT. this way just use Node-Red as a bridge.
solution A is let two controller work directly without any other software.
Threads: 3
Hi admin,
I'm having a hard time to integrate the E16S ESP devices and MQTT.
How do I code the yaml files for the e16s to establish MQTT topics for each momentary switch to toggle the outputs?
Regards,
Keith
Threads: 3
Thanks for the reply and example yaml.
I wish to use MQTT within Home Assistant. Ideally, I wish to leverage Node-Red as a bridge and use the ESPHome In and Out (recognizes all E16S devices and entities), and MQTT input and output nodes to manage the switches and relays of the E16S boards (there will be 6 when I finish this home automation setup).
The A8S code you shared doesn't reflect the gpio platform code lines for the outputs of the E16S. Should I add as follows;
pcf8574: pcf8574_hub_out_2
number: 7
mode: OUTPUT
unique_id: kc868-e16s-output-16
state_topic: 'KC868_E16S/08F9E08B1F58/STATE'
command_topic: 'KC868_E16S/08F9E08B1F58/SET'
payload_on: '{"output1":{"value":true}}'
payload_off: '{"output1":{"value":false}}'
state_on: true
state_off: false
How can I add code for the inputs?
pcf8574: pcf8574_hub_in_1
mode: INPUT
Threads: 1,204
Yes, your OUTPUT config is correct. INPUT example as these:
- name: 'input-1'
unique_id: input-1
payload_on: true
payload_off: false
