KC868-A16 PWM LED
Wink
Is there a way to use the KC868-A16 Board to directly control an LED using PWM or are all mosfets only controllable using the PCF8574 I/O Expander?
Thank you!
A16 only use for ON/OFF by mosfet, can't output PWM.
Good day admin, i just received my KC868-A16 board. can i use the same esp home yaml code from my "A16S"  to my new "A16"? Is the
pcf8574 address, id of the input and output the same? Please can you correct the code below. thanks.
Smart Home Automation Forum › Technical Support › KC868-A16S
KC868-A16S configure yaml for ESPhome
New Reply Thread Rating:
12345
Threaded Mode
admin Offline
Administrator
  platform: ESP32
  board: esp32dev
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
#  manual_ip:
#    static_ip: 192.168.1.199
#    gateway: 192.168.1.1
#    subnet: 255.255.255.0
pcf8574:
    address: 0x24
    address: 0x25
    address: 0x22
    address: 0x23
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
here is A16 yaml file: https://www.kincony.com/forum/showthread.php?tid=1628
you can compare.
Thank you sir for your help. Newbies like me really appreciate it. =)
you are welcome.
