Threads: 10
06-14-2023, 08:43 PM
(This post was last modified: 06-14-2023, 08:44 PM by philippe.)
I want to connect a TC 100 sensor on an analog port. How to caliber the result to get the right temperature (instead of value like "650")?
I am using KCS.
Thanks
Threads: 1,385
do you have TC100 PDF datasheet file? what's signal output?
Threads: 1,385
because our board input range is dc 0-5v, i see your pdf have showed 3 voltage with temperature. i am not sure when your sensor 0-5v means whtat temperature range. you can test, if really hard to use, just replace with DS18B20 is easy to use. we will release new "KCS" V2 soon.
