KC868-1U configure yaml for ESPhome Home assistant
.txt   KC868-1U-ha-config.txt (Size: 5.76 KB / Downloads: 411)
  platform: ESP32
  board: esp32dev
remote_receiver:
  pin: 13
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 16
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
 # manual_ip:
 #   static_ip: 192.168.1.199
#    gateway: 192.168.1.1
#    subnet: 255.255.255.0
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
    on_press:
      then:
        - switch.toggle: light1
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light2
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light3
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light4
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light5
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light6
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light7
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light8
      number: 7
      mode: INPUT
  - platform: remote_receiver
    rc_switch_raw:
      code: '001111010111001010111000'
      protocol: 1
    on_press:
      then:
    filters:
      - delayed_off: 200ms
    rc_switch_raw:
      code: '001111010111001010111100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010111001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110010'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110101'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110011'
      protocol: 1
    on_press:
      then:
    filters:
dallas:
  - pin: 14
    update_interval: 5s
  - platform: dallas
    address: 0xa538cee908646128
    name: "1U Temperature"
