06-21-2023, 09:59 PM
i am trying to configure a Light/humidity/temperature modbus sensor with kincony Ap modbus port in esphome. below is my configuration and sensor data sheet is attached,I am getting this error in the esphome logs
"No response recieved removed from send queue"
Can point what I am doing wrong.
friendly_name: Kincony-Esp32-Dimmer
esp32:
board: esp32dev
framework:
type: arduino
encryption:
key: "7p6IWmIbZjSt7YFWX2bKaCBB1bTmhraTZo+P4cV7BoE="
ota:
password: "2aa38947ee1ec3376d4e0b941ce919da"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Kincony-Esp32-Dimmer"
password: "uIm62IkfOTJ0"
captive_portal:
web_server:
port: 80
#Modbus Configuration for Sensors
uart:
tx_pin: GPIO33
rx_pin: GPIO14
baud_rate: 9600
modbus:
uart_id: mbus
send_wait_time: 200ms
modbus_controller:
- id: light_sensor1
address: 1
modbus_id: modbus1
update_interval: 1s
# Example configuration entry
# ethernet:
# type: LAN8720
# mdc_pin: GPIO23
# mdio_pin: GPIO18
# clk_mode: GPIO17_OUT
# phy_addr: 0
sda: 4
scl: 16
pcf8574:
- id: 'pcf8574_hub_in_1' # for input channel 1-8 maybe 0x22 / 0x3A
address: 0x3A
address: 0x21
- platform: modbus_controller
modbus_controller_id: light_sensor1
name: "Light Intensity"
address: 0x02
unit_of_measurement: "Lux" ## for any other unit the value is returned in minutes
register_type: read
value_type: U_WORD
accuracy_decimals: 1
address: 0x01
unit_of_measurement: "C" ## for any other unit the value is returned in minutes
register_type: read
value_type: U_WORD
address: 0x00
unit_of_measurement: "%" ## for any other unit the value is returned in minutes
register_type: read
value_type: U_WORD
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
pcf8574: pcf8574_hub_in_2
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 34
number: 35
pca9685:
frequency: 500
output:
- platform: pca9685
pca9685_id: 'pca9685_hub'
channel: 0
- platform: pca9685
channel: 1
- platform: pca9685
channel: 2
- platform: pca9685
channel: 3
- platform: pca9685
channel: 4
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 7
- platform: pca9685
channel: 8
- platform: pca9685
channel: 9
- platform: pca9685
channel: 10
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
- platform: pca9685
channel: 13
- platform: pca9685
channel: 14
- platform: pca9685
channel: 15
light:
- platform: monochromatic
output: PWM0
output: PWM1
output: PWM2
output: PWM3
output: PWM4
output: PWM5
output: PWM6
output: PWM7
output: PWM8
output: PWM9
output: PWM10
output: PWM11
output: PWM12
output: PWM13
output: PWM14
output: PWM15
- platform: rgbw
red: PWM1
green: PWM2
blue: PWM3
white: PWM4
pin: 13
inverted: false
pin: 2
inverted: false
