before you config ymal file, please upload zmpt101b folder to home assistant disk:
unzip files, 3 files upload to disk folder as image.
zmpt101b.zip (Size: 1.83 KB / Downloads: 1,768)
KC868-M16v2-ESPHome.txt (Size: 9.55 KB / Downloads: 1,453)
includes:
- zmpt101b/ZMPT101B.h
- zmpt101b/ZMPT101B.cpp
- zmpt101b/zmpt101b_custom_sensor.h
esp32:
board: esp32dev
framework:
type: arduino
encryption:
key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
sda: 4
scl: 5
cd74hc4067:
- id: cd74hc4067_1
pin_s0: 32
pin_s1: 33
pin_s2: 13
pin_s3: 16
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_2).state);
- platform: custom
lambda: |-
auto my_sensor34 = new ZMPT101BSensor(34);
auto my_sensor36 = new ZMPT101BSensor(36);
auto my_sensor39 = new ZMPT101BSensor(39);
App.register_component(my_sensor34);
App.register_component(my_sensor36);
App.register_component(my_sensor39);
return {my_sensor34, my_sensor36, my_sensor39};
sensors:
- name: "m16--AI zmpt 34"
unit_of_measurement: V
accuracy_decimals: 1
state_class: "measurement"
- name: "m16--AI zmpt 36"
- name: "m16--AI zmpt 39"
- platform: sht3xd
temperature:
name: "sht Temperature"
humidity:
name: "sht Humidity"
address: 0x44
update_interval: 5s
- platform: adc
pin: 35
update_interval: never
attenuation: 11db
# - platform: adc
# name: "m16--AI-1"
# pin: 36
# id: adc36
# update_interval: 60s
# attenuation: 11db
# - platform: adc
# pin: 34
# name: "m16--AI-2"
# id: adc34
# attenuation: 11db
# - platform: adc
# pin: 39
# name: "m16--AI-3"
# id: adc39
# attenuation: 11db
- platform: cd74hc4067
sensor: adc35
number: 1
sensor: adc35
number: 2
sensor: adc35
number: 3
sensor: adc35
number: 4
sensor: adc35
number: 5
sensor: adc35
number: 6
sensor: adc35
number: 7
sensor: adc35
number: 8
sensor: adc35
number: 9
sensor: adc35
number: 10
sensor: adc35
number: 11
sensor: adc35
number: 12
sensor: adc35
number: 13
sensor: adc35
number: 14
sensor: adc35
number: 15
sensor: adc35
- platform: ct_clamp
sensor: ai1
name: "Measured Current-1"
update_interval: 5s
filters:
- calibrate_linear:
# Measured value of 0 maps to 0A
- 0.0034 -> 0
# Known load: 4.0A
# Value shown in logs: 0.1333A
- 0.31749 -> 8.95608
- platform: template
lambda: return id(Measured_Current_1).state * id(voltage_1).state;
device_class: power
unit_of_measurement: 'W'
- platform: total_daily_energy
name: "Total Daily Energy1"
power_id: power1
filters:
- multiply: 0.001
unit_of_measurement: kWh
accuracy_decimals: 3
icon: mdi:clock-alert
device_class: energy
sensor: ai2
name: "Measured Current-2"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai3
name: "Measured Current-3"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai4
name: "Measured Current-4"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai5
name: "Measured Current-5"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai6
name: "Measured Current-6"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai7
name: "Measured Current-7"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai8
name: "Measured Current-8"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai9
name: "Measured Current-9"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai10
name: "Measured Current-10"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai11
name: "Measured Current-11"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai12
name: "Measured Current-12"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai13
name: "Measured Current-13"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai14
name: "Measured Current-14"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai15
name: "Measured Current-15"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai16
name: "Measured Current-16"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
time:
- platform: sntp
