Threads: 1
I have a problem with the board... Channels 0, 3, 7, and 13 are always powered.
I have disconnected everything from the board except the power and only in those 4 channels always have 24v at the output.
Is it a board or programming problem? I think it's the board because the other outputs work fine...
What can I do?
Threads: 1,479
08-08-2023, 01:30 PM
(This post was last modified: 08-08-2023, 01:31 PM by admin.)
do you use by home assistant via esphome?
now we have released "KCS" v2 firmware for KC868-AP, i think you can download "KCS" firmware for a test.
Threads: 1
I have installed the KCS firmware and the same thing keeps happening, It seems like a hardware error...
When I connect some led it always is on. 4 useless channels...
Threads: 1,479
can you take a photo how your wire your board.
Threads: 1,479
if you exchange channel1 and channel2's LED, whether also is channel2 always ON. i just want to confirm, whether the LED strip have different.
Threads: 1
If I exchange channel1 and channel2's LED, always CHANNEL 1 is ON. Is not a strip led problem... The problem is the board hardware...
Threads: 1,479
give me your order number, which online store URL you have bought.
Threads: 1,479
received, we have check, you have bought from our agent, not our official online store. we will let their seller send message by aliexpress to help you.
