tasmota zigbee firmware for AG Pro controller
tasmota config module GPIO for Zigbee module RXD,TXD pins:
AG Pro work with Xiaomi Zigbee temperature & humidity sensor:
tasmota zigbee firmware download:
.zip   tasmota32_CP2652.zip (Size: 1.03 MB / Downloads: 779)
or you can download newest firmware from tasmota official webpage:
http://ota.tasmota.com/tasmota32/release/
ESP flasher for ESP32, ESP32-C3, ESP32-S2, ESP32-S3 and ESP8266 (Tasmota) download:
https://github.com/Jason2866/ESP_Flasher/releases
I brought the model KC868-AG Pro and have flashed with Tasmota 14.10 (tasmota32-zbbrdgpro.bin) from, https://ota.tasmota.com/tasmota32/release/
What is the template configuration for all functions such as RF, IR, Zigbee, Tuya module?
you can compile own tasmota firmware which function you needed.
you can see here: https://www.kincony.com/forum/showthread.php?tid=5432
Thumbs Up
Thank you
I am not into coding so i am unable to follow the document.  Huh
It will be better if the kincony support can provide a bin file which enables all the features such as IR, RF, Zigbee & Tuya by default.
sorry, now the zigbee function only use by tasmota. if you only want to use IR and RF, you can download KCS firmware, here is download link: https://www.kincony.com/forum/showthread.php?tid=3791 just download KC868-AG's firmware.
Wink
Im getting an error when trying to flash
[Image: AP1GczO0MI2tyEFpaPiE6CiC3q_vYlGJ27O6pCja...authuser=0]
use ESP32 download tool, here is download link: https://www.kincony.com/esp-module-flash...tools.html
Thank you.
I have flashed it with Software Version v2.2.2
I want to use the RF remote to on/off a Zigbee based switch, I was able to find the RF option. How can i configure the Zigbee Switch to on and off?
our firmware no zigbee function now. do your zigbee device support HTTP command for integration?
if YES, you can use IFTTT command, RF trigger zigbee device.
[attachment=5689 Wrote:pid='15497' dateline='1722259172']
This is the switch, I am not sure if this supports what you are asking for.
