KC868-D16 home assistant configuration.yaml
I have performed the same settings as in the link you provided websit ,
https://www.kincony.com/d16-dimmer-integ...-mqtt.html
but it is giving me an "Unknown" and I am unable to control it through Home Assistant.
12345 post password used in page web off KC868-D16
mqtt:
  light:
  - name: D16-1
    unique_id: D16-1
    schema: template
    command_topic: "dimmer/xxxxxxxxxxxxxxxxxxxxxxxxx12345/set"
    state_topic: "dimmer/xxxxxxxxxxxxxxxxxxxxxxxxx12345/state"
    command_on_template: >
      {%- if brightness is defined -%}
      ,{"dimmer1":{"value":{{(brightness / 255 * 100) | int - 1}}}
      {%- else -%}
      ,'{"dimmer1":{"value":99}}'
      {%- endif -%}
    command_off_template: '{"dimmer1":{"value":0}}'
    state_template: >
      {%- if value_json.dimmer1.value == 0 -%}
        off
      {%- else -%}
        on
      {%- endif -%}
    brightness_template: '{{(value_json.dimmer1.value / 99 * 255)| int}}'
  - name: D16-2
    unique_id: D16-2
    schema: template
      ,{"dimmer2":{"value":{{(brightness / 255 * 100) | int - 1}}}
      {%- else -%}
      ,'{"dimmer2":{"value":99}}'
      {%- endif -%}
    command_off_template: '{"dimmer2":{"value":0}}'
    state_template: >
      {%- if value_json.dimmer2.value == 0 -%}
        off
      {%- else -%}
        on
      {%- endif -%}
    brightness_template: '{{(value_json.dimmer2.value / 99 * 255)| int}}'
Can you please fix this issue or provide me with the configuration file? I have three KC868-D16 devices, and I want to use them with Home Assistant.
it's wrong, XXXXXXXXXXXXXXXXX is your UID, you can check your UID by ethernet webpage.
Actually, I am using the UID as I mentioned, but instead of it, I placed the XXXX symbol.
light:
- name: D16-1
unique_id: D16-1
schema: template
command_topic: "dimmer/41a2d806af7a99020d25f2ae12345/set"
state_topic: "dimmer/41a2d806af7a99020d25f2ae12345/state"
{%- else -%}
{%- endif -%}
state_template: >
off
{%- else -%}
on
{%- endif -%}
- name: D16-2
unique_id: D16-2
schema: template
{%- else -%}
{%- endif -%}
state_template: >
off
{%- else -%}
on
{%- endif -%}
why added 12345? it not need , just use:
command_topic: "dimmer/41a2d806af7a99020d25f2ae/set"
state_topic: "dimmer/41a2d806af7a99020d25f2ae/state"
I deleted the post password 12345.
Everything worked perfectly just as you had said.
Thank you very much indeed.
ok
I am having a similar issue. My D16 is not publishing or reading from the MQTT Server.
https://ibb.co/7SqPTnr
[Image: 7SqPTnr]
I am watching the MQTT server and the 868-D16 never publishes the STATE
https://ibb.co/ssNhsDh
[Image: ssNhsDh]
what's set in your mqtt broker for topic.
