Threads: 4
This is the log. Will try new address
[19:30:55][C][logger:302]: Level: DEBUG
[19:30:55][C][logger:303]: Log Baud Rate: 115200
[19:30:55][C][logger:305]: Hardware UART: UART0
[19:30:55][C][i2c.arduino:053]: I2C Bus:
[19:30:55][C][i2c.arduino:054]: SDA Pin: GPIO4
[19:30:55][C][i2c.arduino:055]: SCL Pin: GPIO5
[19:30:55][C][i2c.arduino:056]: Frequency: 50000 Hz
[19:30:55][C][i2c.arduino:059]: Recovery: bus successfully recovered
[19:30:55][I][i2c.arduino:069]: Results from i2c bus scan:
[19:30:55][I][i2c.arduino:075]: Found i2c device at address 0x21
[19:30:55][I][i2c.arduino:075]: Found i2c device at address 0x22
[19:30:55][I][i2c.arduino:075]: Found i2c device at address 0x24
[19:30:55][I][i2c.arduino:075]: Found i2c device at address 0x25
[19:30:55][C][pcf8574:021]: PCF8574:
[19:30:55][C][pcf8574:022]: Address: 0x24
[19:30:55][C][pcf8574:023]: Is PCF8575: NO
[19:30:55][C][pcf8574:022]: Address: 0x25
[19:30:55][C][pcf8574:022]: Address: 0x21
[19:30:55][C][pcf8574:022]: Address: 0x22
Threads: 1,579
if you short digital input port with GND, whether INPUT state will changed in home assistant.
i want to know whether trigger is correctly, only state is exchanged.
Threads: 4
After playing sometime, I didn't get it to work correctly. I decided to install MQTT server on home assistant and configure Kincony KCS v2 firmware with MQTT. Now it is working fine. I think using MQTT is better because I can use KCS and home assistant at the same time. KCS doesn't depend on network, so in case the network switch goes down, I can still control my home with physical switches.
Threads: 1,579
yes, it's right.KCS work in locally.
Threads: 4
The TCP mode and KBOX app work unreliably. After turning on a few outputs, the KBOX doesn't response to turn on/off switch anymore.
The MQTT via home assistant can still control the A16, so I believe it was the TCP mode is blocked somehow.
After unplug the device, the TCP and KBOX work again. What is the reason?
Threads: 1,579
we not suggest to use KBOX mobile phone app for KC868-A series board. that mainly use for KC868-H series controller.
what software you want to use? home assistant or tuya app?
