KC868-M16v2 configure yaml for ESPhome using Tuya app
work by Tuya app remote monitor by internet.
how to order tuya license see here:
https://www.kincony.com/forum/showthread.php?tid=2544
upload zmpt101b folder to your home assistant folder as this:
.zip   zmpt101b.zip (Size: 1.8 KB / Downloads: 769)
ymal file download:
.zip   m16v2.zip (Size: 2.18 KB / Downloads: 907)
substitutions:
  zmpt101b_sensitivity: "533.75"
  friendly_name: ${name}
  includes:
    - zmpt101b/ZMPT101B.h
    - zmpt101b/ZMPT101B.cpp
    - zmpt101b/zmpt101b_custom_sensor.h
external_components:
  # - source:
  #     type: local
  #     path: my_components/esphome-tuya-iot/components
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-tuya-iot
esp32:
  board: esp32dev
  framework:
    type: arduino
  encryption:
    key: "bw/rPHdwHVn/1VcrLR3klCXs3KieOgLLzS5lr4uXAMI="
ota:
  password: "bd01aad7e00d3e47eaff147d8e37b6de"
tuya_iot:
  product_id: trt1ssh9tckaoxof
  device_id: 26d09e3ccf9314f1eblodu
  device_secret: hzwwkVtJG3GvJzff
# how to order tuya license please check with KinCony's forum
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - lambda: |-
            static int display_voltage = 0;
            display_voltage = (display_voltage + 1) % 3;
            id(display_voltage_id).publish_state(display_voltage);
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
      it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
      if (id(display_voltage_id).state == 0)
        it.printf(0, 40, id(roboto), "AC1:%.1fV", id(voltage_1).state);
      else if (id(display_voltage_id).state == 1)
        it.printf(0, 40, id(roboto), "AC2:%.1fV", id(voltage_2).state);
      else
        it.printf(0, 40, id(roboto), "AC3:%.1fV", id(voltage_3).state);
# Example configuration entry
  - platform: template
    name: "Display Voltage ID"
    accuracy_decimals: 0
    update_interval: never
  - platform: custom
    lambda: |-
      auto my_sensor34 = new ZMPT101BSensor(34, ${zmpt101b_sensitivity});
      auto my_sensor36 = new ZMPT101BSensor(36, ${zmpt101b_sensitivity});
      auto my_sensor39 = new ZMPT101BSensor(39, ${zmpt101b_sensitivity});
      App.register_component(my_sensor34);
      App.register_component(my_sensor36);
      App.register_component(my_sensor39);
      return {my_sensor34, my_sensor36, my_sensor39};
    sensors:
      - name: "m16v2-voltage-1"
        unit_of_measurement: V
        accuracy_decimals: 1
        state_class: "measurement"
      - name: "m16v2-voltage-2"
      - name: "m16v2-voltage-3"
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 10s
  - platform: adc
    pin: 35
    attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    update_interval: 60s
    number: 1
    sensor: adc35
    number: 2
    sensor: adc35
    number: 3
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
interval:
  - interval: 15s
    then:
      - lambda: !lambda |-
          id(tuya_iot_component).property_report("voltage_1", id(voltage_1).state);
          id(tuya_iot_component).property_report("voltage_2", id(voltage_2).state);
          id(tuya_iot_component).property_report("voltage_3", id(voltage_3).state);
          id(tuya_iot_component).property_report("temperature", id(temperature).state);
          id(tuya_iot_component).property_report("humidity", id(humidity).state);
          id(tuya_iot_component).property_report("measured_current_1", id(Measured_Current_1).state);
          id(tuya_iot_component).property_report("measured_current_2", id(Measured_Current_2).state);
          id(tuya_iot_component).property_report("measured_current_3", id(Measured_Current_3).state);
          id(tuya_iot_component).property_report("measured_current_4", id(Measured_Current_4).state);
          id(tuya_iot_component).property_report("measured_current_5", id(Measured_Current_5).state);
          id(tuya_iot_component).property_report("measured_current_6", id(Measured_Current_6).state);
          id(tuya_iot_component).property_report("measured_current_7", id(Measured_Current_7).state);
          id(tuya_iot_component).property_report("measured_current_8", id(Measured_Current_8).state);
          id(tuya_iot_component).property_report("measured_current_9", id(Measured_Current_9).state);
          id(tuya_iot_component).property_report("measured_current_10", id(Measured_Current_10).state);
          id(tuya_iot_component).property_report("measured_current_11", id(Measured_Current_11).state);
          id(tuya_iot_component).property_report("measured_current_12", id(Measured_Current_12).state);
          id(tuya_iot_component).property_report("measured_current_13", id(Measured_Current_13).state);
          id(tuya_iot_component).property_report("measured_current_14", id(Measured_Current_14).state);
          id(tuya_iot_component).property_report("measured_current_15", id(Measured_Current_15).state);
          id(tuya_iot_component).property_report("measured_current_16", id(Measured_Current_16).state);
time:
  - platform: sntp
  - platform: homeassistant
