11-05-2023, 03:00 AM
platform: ESP32
board: esp32dev
sda: 4
scl: 5
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
pcf8574:
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
- platform: adc
pin: 36
name: "A8S A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 34
name: "A8S A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 35
name: "A8S A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 39
name: "A8S A4 Current"
update_interval: 5s
attenuation: 11db
filters:
KC868-A8S-ha-config-ADC_voltage_current.txt (Size: 3.98 KB / Downloads: 832)
