Threads: 10
Good afternoon. Please tell me what is the best way to connect a heated floor, but to regulate not only the temperature that we connect to the KC868-COLBS, but also using a thermostat? I couldn't find a connection diagram on the forum. I understand that we connect the heated floor itself to the reley controller, and the temperature sensors to the KC868-COLBS , but how can we add a thermostat to this circuit? And which one will work best with the kinocny product??
Maybe there is a diagram? I didn't find any information on the forum
Threads: 1,560
11-26-2023, 11:56 PM
(This post was last modified: 11-26-2023, 11:56 PM by admin.)
what control way supportted by your heated floor? just relay for ON/OFF? or it have a IR remoter?
Threads: 1,560
if only control by ON/OFF, suggest to chose KC868-H32B Pro smart relay controller, easy to use.
Threads: 1,560
just let H32B Pro relay output COM,NO series connect with your heat wire.
Threads: 1,560
"when I turn on the heated floor through the button" -- which button? your own warm system's button? or H32B Pro's manual control button (KC868-AK's button)?
