KC868-COLB V1.9 new firmware update
improvement:
1. fixed work with some router maybe have DHCP problem.
2. add the "loop" mode for IFTTT "THEN" command. Now you can set times=255 will alway running the "THEN" command, never stop.
KC868-COLB V1.9 firmware download:
.zip   AD_COLB_V1_1_9_210803.zip (Size: 41.58 KB / Downloads: 1,009)
download the ZIP file , unzip update the bin file for KC868-COLB logical controller.
Is there a way to flash the firmware through the web interface OTA?
Now only by RS232 cable, maybe in furture we will improve it.
I updated the firmware of my COLB to V1.9 and I can't login the http page via ethernet after this.
I used admin/admin ,I used admin and null in password , and I use admin and the last password I use
I try to press the ethernet bottom for 5 sec like in the other post I see (KC868-COLB Password Error After Firmware Update (kincony.com)
and always shows "user or password error!" message.
How can I proceed to fix this?
after update, first time , you can use user name: admin password: jingkong to login, then you change your password by yourself.
