Threads: 3
We want to developp an plc with a embedded web server.
The plc will be usable with a very short lesson.
For doing that, we need a 8 or 16 Mo of memory.
Do you know if it is possible to buy card with an adapted cpu? Is that possible to change the existing cpu?
Many thanks for your response.
Best regards!
Thierry
Threads: 1,204
we are desinging new board will use by ESP32-S3 chip with 16M.
Threads: 3
Hello ,
Many thanks for your reply ,
In how many time do you think you will have card with 16 mo?
Best regards.
Thierry Vorms
Threads: 3
We are developping a software PLC very easy to use.
The plc is web based for the config.
It can use modbus and will have complex component like servo drive.
May be Kincony can support the project ?
We already have the main modulses running.
In short delay we must have an ESP32 with 8 or 16 Mb.
May be we will try to extract the 4Mb and replace it to the new one.
We must to know when cards will be available with more adapted CPU.
Best regards
Thierry Vorms
Threads: 3
Thanks for your reply.
Wich card are you developping using new chip? Allons them? A8?
Best regards
Threads: 1,204
new board will use "ESP32-S3-WROOM-1U-N16R8". it have 32 channel relay.
Threads: 3
Ok, for card like A6 or A8, is that possible to buy card without cpu or cpu 16 Mo?
Threads: 1,204
all board is installed ESP32 module. you can remove it by yourself.
Threads: 3
Just to be schur,
Is that possible to remove the cpu and place an esp32 wrover N16R8?
It's very important for our project
Best regards
