Threads: 2
Device: K868-AG PRO loaded with 2.2.2 as it, no added component
Blind remote model: AC123-02D
Tried RF learning via the KCS firmware 2.2.2, wasn't successful.
Aircon remote: Mitsubishi Aircon Remote
Tried to IR learn as well, it was successful but unable to transmit.
Any recommendation?
Threads: 1,549
maybe your RF remote wireless code not support, usually use by 433MHz RF EV1527 or PT2262 code.
Threads: 2
what about the aircon ir remote able to learn but not able to transmit?
Threads: 1,549
how about other IR device? such TV?
Threads: 2
Mine is a AG pro, you are right, it has zigbee, but you have to use tasmota and not KCS.
And if I use tasmota, I cannot use the IR or the 433 transceiver.
I am sold by KCS firmware because if IFFT
Threads: 1,549
zigbee mainly use by home assistant work as ZHA component or work as Zigbee2Mqtt.
Threads: 2
12-15-2023, 03:36 AM
(This post was last modified: 12-15-2023, 03:42 AM by ayeosq.)
Don't get me wrong, I have no doubt your hardware covers all these communication components.
But KCS lack the following:
1) Act as a Zigbee Hub, simple ifft control over Zigbee
2) 433MHz should support common blind remote for dooya products and A-ok products.
A BROADLINK RM4 PRO can actually do all with a ready interface.
Threads: 1,549
tasmota also can learn IR and RF signal. they called "RULE" command instead of IFTTT.
