Threads: 12
I was wondering if it was possible to use a small display that warns of the status of the outputs or inputs of COL.
in the photo I put a led (far right) that warns me of a condition (lack of pellets in the boiler). but I would like a small lcd or display, maybe settable. is there anything compatible?
Image(s)
Threads: 12
it is a bit too much, something finer that integrates into the wall plates. even with less information, 3 or 4 are enough for me.
Threads: 1,204
you can use a 86mm*86mm size HMI , program by yourself to read any state of KC868-COL.
Threads: 12
here, this is interesting.
which display can I use and how can I program it?
Threads: 1,204
you can search many HMI device by online store.
Threads: 1,204
no, can't directly, it's a IIC bus display, you need to write program code. acutally COL not have a IIC extender.
Threads: 12
is there any small display that COL can control by itself?
Threads: 1,204
03-09-2023, 11:09 PM
(This post was last modified: 03-09-2023, 11:09 PM by admin .)
if you use home assistant software, you can install it in any android small pad.
