platform: ESP32
board: esp32dev
# Example configuration entry
- id: bus_a
sda: 16
scl: 5
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
pcf8574:
- id: 'pcf8574_hub_out_1' # for output channel 1-12 CS1-CS3
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 13-24
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_in_2' # for a24--input channel 17-32
i2c_id: bus_a
address: 0x25
pcf8575: true
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
# Individual inputs
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
pcf8574: pcf8574_hub_in_2
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
- platform: adc
pin: 35
name: "A24 A1 Voltage"
update_interval: 10s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 34
name: "A24 A2 Voltage"
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 39
name: "A24 A3 Current"
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 36
name: "A24 A4 Current"
attenuation: 11db
filters:
- platform: max31855
name: "K-Type Thermocouple-1"
cs_pin:
number: 13
mode: OUTPUT
inverted: false
update_interval: 5s
name: "K-Type Thermocouple-2"
cs_pin:
number: 14
mode: OUTPUT
inverted: false
update_interval: 5s
name: "K-Type Thermocouple-3"
cs_pin:
number: 15
mode: OUTPUT
inverted: false
update_interval: 5s
spi:
- id: spi_bus0
clk_pin: 14
miso_pin: 12
gp8403:
voltage: 10V
output:
- platform: gp8403
gp8403_id: my_gp8403
channel: 0
- platform: gp8403
channel: 1
light:
- platform: monochromatic
output: gp8403_output_1
output: gp8403_output_2
A24-ESPHome.txt (Size: 10.11 KB / Downloads: 489)
