Threads: 8
After configuring Home Assistant, I managed to control my KC868-A16S module with it. However, I lost access to my module’s interface with the IP address 192.168.1.76. It’s important to note that before setting up Home Assistant, I was always able to connect to the module’s interface with this IP address. Can you assist me with this problem?
Threads: 1,560
do you download firmware by ESPHome? or you use KCS firmware? please write your problem in details.
Threads: 1,560
after downloaded KCS firmware, MUST re power on of your KC868-A16S board.
your PC and A16S must connect to same router in one local network.
Threads: 8
01-02-2024, 10:30 AM
(This post was last modified: 01-02-2024, 11:09 AM by Lamri.)
thank you, I managed to access a web page where there are inputs and outputs, but unfortunately I cannot access the various IFTTT, RF, SMS, CALL services…
Threads: 1,560
i have said, you are using ESPHome firmware, not use by KCS now. KCS firmware already overwrite by ESPHome's firmware.
