Threads: 42
I have a very long facade, 100 meters, and it will have 5 circuits of RGB LED strip lights. This means each circuit will be 100 meters long, which equals 20 reels of RGB LED strip lights in total. I want to know the required controller, power supply, and how to connect between the controller and the LED reels.
Threads: 1,545
if use by long distance, suggest chose DC24v LED strip. what software you will use? home assistant?
Threads: 42
home assistant
I want to know the required controller, power supply amper , and how to connect between the controller and the LED reels , between reels.
