Threads: 2
I am making a kc868-16 connection with esphome firmware, to connect directly to node red, but the connection is unsuccessful, I have the latest KC firmware.
What should be the ports to use for the connection?
thank you so much
Threads: 691
if you want to use home assistant, you can use ESPHome.
if you want to use Node-red, you can download KCS firmware to ESP32, then use MQTT integrate to Node-red.
Threads: 2
02-12-2024, 06:50 PM
(This post was last modified: 02-12-2024, 06:59 PM by Als Santa.)
Perfect, Tks!!!
how do I do it, with: npm install node-red-contrib-kincony ?
