Threads: 1,309
if can't learn signal , that means your RF remote not use common wireless keycode, it's private keycode. we support EV1527 or PT2262 wireless code, it's widely used in market.
Threads: 2
Hello, thank you for your answer
is there a way to write code to support other thing
is there a way to access raw data received by the sensor ?
Threads: 1,309
i think you can use ESHome config the board, decode RF RAW data by esphome.
Threads: 2
Thank you for your answer, I will give a try to espHome
any .yaml file suggestion for k868-AG ?
Threads: 2
With ESPHome I receive what is called Pronto data
However, the data are slightly different from one attempt to the other and it is also a lot of data each time.
I suppose the signal is sent several times and not received exactly the same each time.
one attempt:
[20:05:39][I][remote.pronto:233]: Received Pronto: data=
[20:05:39][I][remote.pronto:235]: 0000 006D 00C1 0000 0005 0018 0007 004E 000D 0013 0004 0034 0006 005E 0004 0002 0008 0053 0006 0018 000B 000A 0002 0023 0005 0010 0016 0013 0007 0026 0004 0021 0006 0003 0005 0004 0003 0015 0008 001A 0009 0017 0009 0035 0003 001A
[20:05:39][I][remote.pronto:235]: 0007 0026 0004 0007 0003 002B 0009 000D 000B 000A 0003 0006 000B 0022 0006 0023 0008 0009 000B 0007 000B 000B 0008 0005 0004 0007 0006 0018 0007 0001 0005 000D 000E 0007 0003 000B 0005 0021 0007 001D 0006 0008 0007 0003 000F 0007
[20:05:39][I][remote.pronto:235]: 0006 001D 0005 0002 000C 000B 0021 0017 0006 0016 0017 0007 0004 0004 0007 0012 0007 0001 0003 0002 0009 0020 0012 0015 0003 0013 0013 0003 0023 0004 000F 0006 0017 0002 0006 000C 0010 0001 0009 0005 0005 000D 0015 0004 0003 0008
[20:05:39][I][remote.pronto:235]: 0006 000B 0018 000B 0008 0008 001C 0012 0005 0007 001C 0004 000B 0003 0006 000B 000B 0008 000B 000F 0011 0005 0009 0008 0017 0003 0004 0004 0006 0004 0005 000E 000C 0004 000C 0003 0007 0005 0006 0007 0027 0009 000F 0001 0020 000D
[20:05:39][I][remote.pronto:235]: 0040 0005 000F 0003 000A 0003 000E 0004 0007 0004 0012 000B 0054 0005 0061 0008 0016 0004 000B 0004 0003 0006 0031 0011 0008 000B 000E 0008 0013 000B 0019 0001 000F 0004 0012 0001 0006 0012 000E 0005 001D 0015 0009 000A 0008 0001
[20:05:39][I][remote.pronto:235]: 0008 0016 000B 000A 0007 0006 0012 0008 0005 0002 0025 000A 0003 0006 0006 0005 0016 0008 0004 0008 0007 0009 0026 000E 0006 0014 0007 0008 000B 0004 000E 0007 000D 0003 0002 0005 0003 0003 0004 000D 000B 0002 000A 0004 0005 0005
[20:05:40][I][remote.pronto:235]: 000C 000D 0016 0005 000C 0003 0006 000B 0007 000F 000E 001B 0012 000D 0004 0005 0004 0005 0027 000A 0007 0005 0011 0017 0005 0001 001E 0003 0016 0004 0005 0014 0013 0009 002C 000A 0006 0008 0002 000C 0005 000C 001A 0003 0017 0017
[20:05:40][I][remote.pronto:235]: 0010 000A 0014 0013 0004 0002 0003 0002 0029 0001 0011 0004 003A 0001 0005 0009 0013 0002 0020 000E 002B 001A 0010 0003 0009 0004 000A 0009 0005 000F 0005 0009 0015 0006 0011 0002 0012 0005 001A 0003 0003 0020 0009 0001 000C 0002
[20:05:40][I][remote.pronto:235]: 0008 0003 000E 0008 0007 0006 0003 0008 000F 000D 0006 001A 0010 0005 0006 0008 0006 0001 000F 000D 009B 06C3
[20:05:40][W][component:214]: Component remote_receiver took a long time for an operation (0.20 s).
[20:05:40][W][component:215]: Components should block for at most 20-30ms.
[20:05:40][I][remote.pronto:233]: Received Pronto: data=
[20:05:40][I][remote.pronto:235]: 0000 006D 002C 0000 0017 000D 0015 000F 0083 0085 0011 0033 0011 0014 0011 0033 0011 0014 0011 0034 0010 0014 0010 0014 0010 0035 0010 0034 0010 0014 0010 0014 0010 0014 0010 0034 0010 0014 0010 0015 0010 0016 0010 0015 0010 0034
[20:05:40][I][remote.pronto:235]: 0010 0015 0010 0034 0010 0015 0010 0034 0010 0034 0010 0016 0010 0015 0010 0034 0010 0034 0010 0034 0010 0014 0010 0034 0010 0034 0010 0035 0010 0034 0011 0014 0010 0015 0010 0015 0010 0015 0010 0034 0010 0034 0010 0034 0010 009B
[20:05:40][I][remote.pronto:235]: 06C3
[20:05:40][W][component:214]: Component remote_receiver took a long time for an operation (0.05 s).
[20:05:40][I][remote.pronto:235]: 0000 006D 0008 0000 0003 006B 000A 0064 0003 0055 0005 0015 000F 0042 0004 0001 0004 0003 0006 009B 06C3
[20:05:40][I][remote.pronto:235]: 0000 006D 0002 0000 0005 006D 0004 009B 06C3
transmitting back the data does not work
any clue ?
