Add KinCony modbus energy meter to home assistant using raspberry pi's RS485 port
how to integrate KinCony modbus energy meter to home assistant using raspberry pi's RS485 port
A. use "inCony_Meter_config_tool" change RS485 " Parity: EVEN "  to " Parity: NONE ", because we found home assistant can't work with "EVEN", KinCony energy meter default setting is "EVEN".
A-1: connect energy meter to PC by USB-RS485 adatper:
A-2: first time, use RS485 setting,  Parity: EVEN (Chinese word on left is : 偶校验)  click "打开" (open serial port) button.
.zip   KinCony_Meter_config_tool.zip (Size: 20.55 KB / Downloads: 665)
A-3: click "无校验" (None) button, set  Parity: NONE
until now,  "Parity" is set completed.
if you want change meter ID from 1, you can "set the meter ID", such as input 1,2,3,.... then click "改表号+读" (write button), it will set the ID for meter.
if you have changed  Parity: NONE, you want connect to serial port again, you need change serial setting,  Parity=None, Chinese word is "无校验",then click "读" (Read) button, you will read all data from meter.
now the meter hardware setting is complete, then you can connect meter to KC868-Server or Server-Mini's RS485 port directly. see photo:
config HA yaml as here:
.txt   KinCony_modbus_meter.txt (Size: 1.43 KB / Downloads: 559)
modbus:
  - name: hub1
    type: serial
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: N
    port: /dev/ttyS0
    stopbits: 1
    sensors:
    - name: meter-voltage
      slave: 1
      address: 100
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: V
      device_class: voltage
    - name: meter-current
      slave: 1
      address: 106
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: A
      device_class: current
    - name: meter-power
      slave: 1
      address: 118
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: kW
      device_class: power
    - name: meter-factor
      slave: 1
      address: 142
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
    #  unit_of_measurement:
      device_class: power_factor
    - name: meter-frequency
      slave: 1
      address: 144
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: Hz
      device_class: frequency
    - name: meter-consumption
      slave: 1
      address: 0
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: kWh
      device_class: energy_storage
add meter to HA dashboard:
You rock sir. Perfectly works.
One comment: I don't use Windows as native OS so I used config tool in windows Virtual Machine. Had to install this driver to get COM recognized: https://www.wch-ic.com/downloads/CH341SER_ZIP.html
Cheers!
ok, good.
meter-consumption is stuck at 0.04 kWh since several weeks and I had a lot of consumption since then.
How to verify if it works correctly?
what's the value on meter's display about it?
if use new home assistant, Please remove count=## lines from the modbus config part of configuration.yaml because now count is only valid for data_type: custom and data_type: string and is invalid for all other data types like int16, uint16 etc.
Hi Kincony, I'm having issues with this modbus meter since I set it up as you indicated me.
For months, the meter-consumption is showing 0.04kWh and not changing value. The only parameters that are showing correctly are the meter-voltage and meter-frequency..
How to fix it?
Attached is a screenshot and this is my config:
  - name: hub1
    type: serial
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: N
    port: /dev/ttyS0
    stopbits: 1
    sensors:
      slave: 1
      address: 100
      input_type: holding
      data_type: float32
      precision: 2
      slave: 1
      address: 106
      input_type: holding
      data_type: float32
      precision: 2
    - name: meter-power
      slave: 1
      address: 118
      input_type: holding
      data_type: float32
      precision: 2
      device_class: power
      slave: 1
      address: 142
      input_type: holding
      data_type: float32
      precision: 2
      slave: 1
      address: 144
      input_type: holding
      data_type: float32
      precision: 2
      slave: 1
      address: 0
      input_type: holding
      data_type: float32
      precision: 2
what's the meter-consumption showed on meter's LCD displayer? whether also is 0.04kWh?
(05-09-2024, 10:37 PM)admin Wrote: what's the meter-consumption showed on meter's LCD displayer?  whether also is 0.04kWh?
I think it's 000000.
Voltage is ~230v
Frequency is ~50
PF is 100
C is 1600
Now I have fours bulbs ON and I see no consumption. How to fix ?
let your bulbs ON for one day, then check the value.
