Threads: 1
02-16-2024, 11:42 AM
(This post was last modified: 02-16-2024, 11:45 AM by admin.)
Hi, I'm having difficulties with this device (KC868-A8). I have it plugged into my ethernet switch with cat6 cable, and into my computer with usb. at first I was able to see the device from ESPHome running on Home Assistant and configure through home assistant. Now it does not detect the device when I try to +New Device it just says initialising but never detects it. Also, the ethernet socket on the device no longer lights up (im sure it had yellow light before when I plug in the ethernet cable).
Has my device's ethernet/serial connection failed?
Threads: 1,322
do you download ESPHome firmware by USB cable? you can connect your A8 board with your PC by USB cable, check it whether can be detected.
Threads: 1
Yes, I've tried plugging usb into my computer (iMac), as well as the raspberry pi with is host for Home Assistant. Home assistant is communicating well between my iMac and the pi. I was able to see the device before on home assistant, now it doesn't detect it.
Im sure the KC868-A8 had a yellow network light on it previously when it was detecting in home assistant? now it doesn't...
Threads: 1,322
when A8 connect to your iMAC, USB device can be detect?
Threads: 1
02-16-2024, 12:11 PM
(This post was last modified: 02-16-2024, 12:11 PM by Skankrabbit.)
Not any more. It did when I first tried it. After 1 day, it no longer detects the device
yes I have the ch341 driver installed
Threads: 1,322
ok, that mean A8 hardware is OK. you can delete esphome device, re add a new device, use another board name for a test.
Threads: 1,322
this is your esphome problem, you can delete your esphome addon, re isntall it.
Threads: 1,322
add whatsapp number: +86-15381188302 when have free time, use ANYDESK remote control your PC to help you.
