Threads: 2
looks good, what is: P-MOSFET output ports?
Threads: 1,551
The metal–oxide–semiconductor field-effect transistor (MOSFET, MOS-FET, or MOS FET), also known as the metal–oxide–silicon transistor (MOS transistor, or MOS), is a type of insulated-gate field-effect transistor that is fabricated by the controlled oxidation of a semiconductor, typically silicon. The voltage of the covered gate determines the electrical conductivity of the device; this ability to change conductivity with the amount of applied voltage can be used for amplifying or switching electronic signals.
Threads: 1
Hi,
is it possible with this controller to use it like dimmer D8 - when the dry contact is pressed the mosfet stays on, and when dry contact is relesed the mosfet is off?
Thank you.
Threads: 1,551
of course, it can use by dry contact for on and off.
Threads: 2
Hi
Is it possible to add the TOGGLE function to the double click mode?
Threads: 2
can the mosfet give power to LED strip directly?
To give 12v or 24v and connect on the output the plus (+) of the LED strip?
Threads: 1,551
it's no problem, but how much amper you will use for LED strip, you should calculate it for chose your extend power supply.
Threads: 2
So if the led strip need for instance 200w and the power supply that i will connect is 300w, it should be ok to pass through the mosfet?
I see on the products parameter that the output load is 12/24v 500mA, that is why i am asking.
