#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574(0x27,4,5); //4 is SDA 5 is SCL need replace by your board's pin define
A0 A1 A2
0 0 0 =0x20
0 0 1 =0x21
0 1 0 =0x22
0 1 1 =0x23
1 0 0 =0x24
1 0 1 =0x25
1 1 0 =0x26
1 1 1 =0x27
unsigned long timeElapsed;
void setup()
delay(1000);
// pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
if (pcf8574.begin()){
Serial.println("OK");
}else{
Serial.println("KO");
void loop()
uint8_t val1 = pcf8574.digitalRead(P0);
uint8_t val2 = pcf8574.digitalRead(P1);
uint8_t val3 = pcf8574.digitalRead(P2);
uint8_t val4 = pcf8574.digitalRead(P3);
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
if (val1==LOW) Serial.println("KEY1 PRESSED");
if (val2==LOW) Serial.println("KEY2 PRESSED");
if (val3==LOW) Serial.println("KEY3 PRESSED");
if (val4==LOW) Serial.println("KEY4 PRESSED");
if (val5==LOW) Serial.println("KEY5 PRESSED");
if (val6==LOW) Serial.println("KEY6 PRESSED");
if (val7==LOW) Serial.println("KEY7 PRESSED");
if (val8==LOW) Serial.println("KEY8 PRESSED");
delay(300);
}arduino code download:
DI8.zip (Size: 594 bytes / Downloads: 501)
PCF8574 arduino library ZIP file download:
PCF8574_library.zip (Size: 23.8 MB / Downloads: 555)
