PCF8574 IO Expansion i2c relay board -DO8 ESPHome config yaml demo
  sda: 4  #replace by your board's pin define
  scl: 5   #replace by your board's pin define
pcf8574:
    address: 0x24    #replace by your PCF8574 address
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
download yaml demo for ESPHome:
.txt   DO8_config_yaml.txt (Size: 1.58 KB / Downloads: 530)
about A0,A1,A2 i2c address setting:
A0  A1  A2
0    0    0    =0x20
0    0    1    =0x21
0    1    0    =0x22
0    1    1    =0x23
1    0    0    =0x24
1    0    1    =0x25
1    1    0    =0x26
1    1    1    =0x27
but with this configuration (OUTPUT) it is not possible to intercept the relay status if operated manually!
BR
E.
yes, this manual control button use by phsical way, it work without software. Just used in emergency situations.
Is there a chance to connect IO expanders to ksc v3 firmware? To control them from your aplication? Idea is to connect your base board like b16 to loxone with that expanders
if you want extend by i2c device, you can use by ESPHome. such as DI8 i2c digital input module and DO8 i2c relay module.
