M30 Pulse Input
I'm migrating from Flukso  towards Kincony M30. I'm new to ESP Home, so for the moment learning how it all works.
For the moment, already 26 CT clamps running nicely. So far, so good. Wink
On my Flukso, I had a water probe (0,5L per pulse) and a gas probe (10L / pulse). To simplify things, I want to use these probes as well to the M30.
  1. Can I just connect these probes to a port on the M30? Similar to the CT clamps?
  2. And if yes, does anybody have an example for the config?
M30 support CT clamp output 0-1v signal. you can confirm the range whether is ok.
