Kc868-AK
HELLO ENGINEER
Naw I am trying to us kc868-AK
Before RS232 worked with kc868-H32b perfectly.
After I updated the esp firmware to config with home assistant suddenly stopped working
And there was a blinking green light that also stopped.
And it's now shown in the home assistant perfect
Can you help me
because you have config the AK work for home assistant, so not support by H32B via RS232 directly.
if you want download before firmware to support H32B directly, here is "factory original firmware" for KC868-AK download:
.zip   kc868-ak-v1.0.7.zip (Size: 453.15 KB / Downloads: 707)
Same rs485 can't work with homeassistant Sametime..
Or can work with homeassistant?
do you understand me? if you use ESPHome for home assistant, RS232 or RS485 all can't work with H32B directly.
