Threads: 4
Hi
My AK board is not connecting to controller. Only one light red showing. It was working before but suddenly stop.
I tried to use a different AK to the same controller but also didn't work.
What should I do?
Threads: 4
Do you have a guide for updating the firmware?
Threads: 4
i dont think the problem is from the AK because i have a different one and i put it instead and still same problem
Threads: 1,204
check your cable. do you use RS232 or RS485 cable?
Threads: 4
04-28-2024, 01:09 PM
(This post was last modified: 04-28-2024, 01:28 PM by mutaz.)
RS232
Connected to KC868-H32B pro
I can control the KC868-H32B pro controller from web and tuya. But AK connected to it ia not responding
Threads: 1,204
check RS232 cable whether have good contact.
when AK board running, the LED will blink, if not "blink" , you can try to download firmware.
another test way : you can try to connect cable with RS485, not use RS232. then make sure your AK and H32B Pro's RS485 config setting is same.
