05-10-2024, 10:49 AM
friendly_name: s3
platformio_options:
board_build.flash_mode: dio
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
type: W5500
clk_pin: GPIO43
mosi_pin: GPIO44
miso_pin: GPIO42
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
uart:
- id: uart_485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 16
rx_pin: 15
- id: uart_sim7600
baud_rate: 115200
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
tx_pin: 18
rx_pin: 17
- platform: uart
uart_id: uart_485
- platform: uart
uart_id: uart_sim7600
data: "AT+CGSN\r\n" # read 4G SIM7600 ID
number: 8
number: 40
number: 39
mode:
input: true
pullup: true
number: 38
mode:
input: true
pullup: true
number: 10
mode:
input: true
pullup: true
number: 11
mode:
input: true
pullup: true
number: 12
mode:
input: true
pullup: true
number: 13
mode:
input: true
pullup: true
number: 14
mode:
input: true
pullup: true
number: 21
mode:
input: true
pullup: true
number: 47
mode:
input: true
pullup: true
number: 48
mode:
input: true
pullup: true
- platform: adc
pin: 4
name: "S3 IO04 Current"
update_interval: 2s
unit_of_measurement: V
attenuation: 11db
filters:
- multiply: 5
- platform: adc
pin: 5
name: "S3 IO05 Current"
update_interval: 2s
attenuation: 11db
filters:
- multiply: 5
- platform: adc
pin: 6
name: "S3 IO06 Current"
update_interval: 2s
attenuation: 11db
filters:
- multiply: 5
- platform: adc
pin: 7
name: "S3 IO07 Current"
update_interval: 2s
attenuation: 11db
filters:
- multiply: 5
web_server:
port: 80
S3-HA.txt (Size: 3.5 KB / Downloads: 682)
maybe in furture we can update, thanks for suggestion.
