Threads: 4
Hello, I'm verry interested in this board( the v2 version)
I have 2 questions.
I need to use 2x AM2301 sensors, is it possible to use them with this board?
Which poe expansion board do I need to add to this board to use poe directly?
Threads: 4
Hello, I placed my order #1019
I ordered the rs485 temp/hum sensor i hope i will get it working with esphome
I didn’t notice your reply nor the analog sensor. I didn't read that its analog a just assumed it was one wire as is looks like am2301 from picture.
Please if you can assemble the poe that would be awesome.
Threads: 1,561
yes, we have checked order #1019, you have not paid.
if you use RS485 sensor, do you will connect to one ESP32 board's RS485 port?
Threads: 4
I paid using wire transfer it will take maybe 2days to go through. I can pm transfer details if needed. Yes i plan on connecting the sensor to a8s rs485. Also if i dont use gsm or rf can i use the pins as gpio?
Threads: 1,561
gsm module's pin can be used. RF pin have connect with IC, unless you remove the IC, so that you can use the free GPIO.
suggest to use GSM's two gpios directly, and easily.
