Threads: 7
Hi, could anyone show me how to solve the following?
I have mini server with home assistant and kc868 - A6 with kincony firmware. I'd like to connect the boards via Rs485 and manage relay and DI of kc868 - A6 from home assistant using Rs485.
Threads: 7
Thanks admin.
I need one more info.
1) It's mandatory to install ESP home in my home assistant to make my Server Mini able to communicate with KC868-A6 via RS485? or it's possible without installing ESP home?
Actually I modified the configuration.yaml in my home assistant as you see
default_config:
frontend:
script: !include scripts.yaml
scene: !include scenes.yaml
uart:
tx_pin: GPIO14
rx_pin: GPIO15
baud_rate: 9600
modbus:
uart_id: mbus
send_wait_time: 200ms
modbus_controller:
- id: a6
address: 1
modbus_id: modbus1
update_interval: 1s
- platform: rpi_gpio
switches:
- port: 5
- port: 22
- port: 17
- port: 4
- port: 6
- port: 13
- port: 19
- port: 26
- platform: modbus_controller
address: 0 # 0:relay1 1:relay2 ......
register_type: coil
bitmask: 1
sensors:
- port: 18
- port: 23
- port: 24
- port: 25
- port: 12
- port: 16
- port: 20
- port: 21
and then restarted home Assistant...unfortunatly there is no modbus-switch1 in the Entity list!
Threads: 1,361
MUST need use RS485 for connection? if use by wifi will be very easy.
let server-mini and A6 connect to same router is ok. install ESPHome, config yaml file for A6.
Threads: 7
Ok. Installed ESP home.
Where could I find a basic yaml file for the A6 board?
Thanks in advance.
Threads: 1,361
download KCS firmware to A6 board, enable RS485 using MODBUS-RTU. just login KCS webpage to set.
