"KCS" v1.0.7 firmware for A32 Pro controller
improvment:
1. changed process worm momory size.
2. added different delay time when turn ALL relay ON
there are some different files for v1.0.7. delay time: 1ms, 5ms, 10ms, 50ms    4 version.
just added different delay time when turn ON all 32 channel relay output, you can chose by yourself. added the delay time will protect your power system, because if you have connected 32 channel contactor work at the same time,it will cause instantaneous impact on the power grid.
.zip   A32PRO_V1.0.7_1ms.zip (Size: 777.64 KB / Downloads: 544)
.zip   A32PRO_V1.0.7_5ms.zip (Size: 777.7 KB / Downloads: 597)
.zip   A32PRO_V1.0.7_10ms.zip (Size: 777.7 KB / Downloads: 607)
.zip   A32PRO_V1.0.7_50ms.zip (Size: 777.63 KB / Downloads: 574)
