Threads: 1,468
i suggest you use SHT31 connect with A8S' i2c extender interface, it's easy for ESPHome.
if you really want to use RS485 bus for long distance. ok, the product's link is ok.
Threads: 1,468
when have free time, we can have a test.
Threads: 4
Can you please send me some more information about the sensor? Default address? Used registers to read etc?
Threads: 4
If some one would be looking for the same thing, this is the part of yaml that works for me:
modbus:
uart_id: mod_bus
modbus_controller:
- id: a8s
address: 0x01
modbus_id: modbus1
setup_priority: -10
update_interval: 5s
uart:
tx_pin: 33
rx_pin: 32
baud_rate: 9600
stop_bits: 1
parity: NONE
- platform: modbus_controller
modbus_controller_id: a8s
register_type: holding
address: 0
unit_of_measurement: "°C"
value_type: S_WORD
accuracy_decimals: 1
filters:
- lambda: return x / 10.0;
address: 1
unit_of_measurement: "%"
value_type: S_WORD
filters:
Threads: 1,468
good, thanks share your code.
Threads: 0
Hello
I want to use several of these sensors in one bus. How can I change the sensor's address? In which registry the address is stored?
Thank you
