433MHz remote_receiver
I am using ESPHome 2024.5.5 on the KC868-A8S device. After uploading the firmware that includes the remote_receiver component on GPIO16 for 433 MHz receiving module, the device becomes unresponsive and the web dashboard returns ERR_CONNECTION_REFUSED. Interestingly, when the remote_receiver component is not included, everything functions as expected.
Any ideas about that? Thank you!
  platform: ESP32
  board: esp32dev
web_server:
  port: 80
ota:
#remote_receiver:
#  pin: GPIO16
#  dump: all
#  tolerance: 50%
#  filter: 250us
#  idle: 2ms
#  buffer_size: 2kb
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
pcf8574:
    address: 0x24
  - id: 'pcf8574_hub_in_1' # for input channel 9-16
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
output:
  - platform: ledc
    pin: GPIO2
rtttl:
  output: buzzer_output
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO12
    num_leds: 1
    rgb_order: GRB
    default_transition_length: 0s
    restore_mode: ALWAYS_OFF
you can test with this yaml whether work well.
.txt   KC868-A8S-ha-config.txt (Size: 6.11 KB / Downloads: 474)
(06-19-2024, 10:32 PM)admin Wrote: you can test with this yaml whether work well.
Your YAML worked, thank you! I've tried to pinpoint what caused the error. It seems that using both remote_receiver and RGB light element does not work well together. I can use remote_receiver or WS2812B.
This is current working configuration:
  platform: ESP32
  board: esp32dev
web_server:
  port: 80
ota:
remote_receiver:
  pin: 16
  dump:
    - raw
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
pcf8574:
    address: 0x24
    address: 0x22
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
output:
  - platform: ledc
    pin: GPIO2
rtttl:
#light:
#  - platform: fastled_clockless
#    chipset: WS2812B
#    pin: GPIO12
#    num_leds: 1
#    rgb_order: GRB
#    name: "rgb_led"
#    id: rgb_led
#    default_transition_length: 0s
#    restore_mode: ALWAYS_OFF
ok
