Threads: 2
hi Admin
is there is any way I can have the source file not the .bin for the A32 pro with RF and SIM modules that has delays of 10 ms?
Because using that file I can't connect it to home assistant .
Thanks,
Threads: 1,206
what do you want to do? let relay will auto off ?
i don't understand.
Threads: 2
With this firmware not able to add to homeassistant.
Threads: 2
Wants to user the Kincony Server and use the SIM and RF features and the other feature IFTTT, etc, also integrate to Home assistant. also be able to dispolay what you have already integrated to display (Ethernet, tuya, wifi.. etc.) in the display.
Threads: 2
06-22-2024, 12:37 PM
(This post was last modified: 06-22-2024, 01:07 PM by hassankash.)
I Already did that also, i downloaded the new version 1.0.7, and configured the mqtt. besides when i'm adding using the mqtt they appear unavailable in home assistant mqtt.
is there is any chance you share the source yaml file for the firmware 1.0.7 or 1.0.5 ?
Threads: 1,206
these days when have free time, i will do that, make a yaml support A32 Pro add to home assistant by MQTT. maybe take a video tour upload to our YouTube.
Threads: 1,206
hold on the TEXT of "Voltage" and "Current". you can rename by yourself.
