Threads: 1
<!-- @page { margin: 2cm } P { margin-bottom: 0.21cm } -->
Bonjour
J'ai plusieurs contrôleurs mais ils ne peuvent pas interagir entre eux en par le contrôleur logique
un conseil;merci .
Threads: 1,281
Can you tell me your questions details? You'd better write in English.
Threads: 1
The analog inputs AI or the digital inputs DI of a KC868 HX controller (Number1) can actuate the relay outputs of another KC 868 HX controller (number2 or other) with the IFTTT program of the KC 868 COL logic controller
Threads: 1,281
one KC868-COL is connect to one KC868-Hx relay controller, one by one. can trigger relay output that not connect with KC868-COL by RS232 cable.
