07-13-2024, 09:49 AM
KC868-E16P is a great product, I love it!
I am almost finished connecting all my sensors and devices using ESPHome.
Only remains 2 EZO sensors (1 device is pH, the other ORP). This is from Atlas Scientific: EZO™ pH Circuit | Atlas Scientific (atlas-scientific.com)
I found this code on EZO sensor circuits — ESPHome
- platform: ezo
address: 99
unit_of_measurement: "pH"
update_interval: 10s
The device is connected to SDA / SCL.
Problem:
- Results from i2c bus scan doesn't detect the EZO sensor (I know the SDA / SCL ports are OK since I am able to detect an additional PCF8574 board for instance).
- While the device isn't detected, it is somehow interfering with ESP32 since I am seeing this in the logs:
[W] [component: 157]: Component pcf8574 set Warning flag: unspecified
[W] [component: 170]: Component pcf8574 cleared Warning flag
Questions:
- How to make my EZO sensor work please ?
- For my second EZO sensor, should I connect it to the IC2 extender ?
Thank you.
- platform: ezo
address: 99
Problem:
Questions:
Thank you.
