Threads: 1
Ive recently received the AG8 IR Controller and I've tried to plug it into my laptop to install my esphome firmware but my laptop is not recognising it. Im using a MacBook but I've tried it on a windows laptop with the sane outcome. Im not too sure if I'm missing something but I've used esphome on multiple boards previously with no issues.
Anyone able t help.
Thanks
Threads: 2
I have an AG8 controller that is supposed to be connected to my router network via ethernet but its unable to , i suspect it could possibly have its own static ip address which is preventing the the router from assigning my AG8 an ip to join the network. I have decided to flash the controller via a flash dowload but got stuck with getting the firmware to use for the flashing . I would be glad if you could assist me on this.
Threads: 1,560
now no firmware inside of new AG8. do you want use for home assistant software?
Threads: 1,560
Do you want to use zigbee? or just want to use IR or RF signal?
Threads: 1,560
whether can find your AC brand in ESPHome IR library? if find it. just send by it's code, not need to learn IR.
