Threads: 9
08-13-2024, 07:19 PM
(This post was last modified: 08-13-2024, 08:34 PM by BaconRanch.)
I changed the jumper to boot from USB C port on CM4 Raspberry Pi and its not booting, no pwer at all in either position. Please advise what else needs to be checked.
Thank you,
Mark @ Bacon Ranch
Threads: 1,281
take a photo how you set. it's better take a video of your problem.
Threads: 9
(08-13-2024, 10:58 PM)admin Wrote: take a photo how you set. it's better take a video of your problem.
It seems like there are only a few options for a jumper, why not just tell us ?
None the less here is another video I have had to make, download, and then upload and share
Please take the device back for a refund.
https://drive.google.com/file/d/1o6k1wtx...sp=sharing
Threads: 9
(08-14-2024, 12:11 AM)lulu01 Wrote: My understanding is that the board needs 12-24V to operate. Are you sure the board is supposed to also be powered via USB-C? The relays need 12V to switch, I don't see the USB-C connector providing this.
https://www.kincony.com/raspberry-pi-iot-gateway.html
I had asked this and was told yes....I have a few R Pis running Home Assistant instances and they all power via USB C . The power supply I am using is designed for R Pi4 and does provide 12V and 2 amps. The jumper apparently is for this purpose but its only 3 pins so it can only be 2 positions or a 3rd option I suppose is no jumper ?
Cheers
Threads: 11
Raspberry Pi 4 is powered at 5V. If you have a power supply that works on a RPI4, it has to be 5V, and I doubt it will power the Kincony board.
Threads: 9
(08-14-2024, 12:24 AM)lulu01 Wrote: Raspberry Pi 4 is powered at 5V. If you have a power supply that works on a RPI4, it has to be 5V, and I doubt it will power the Kincony board.
thats right, I meant 5V 2A....wish this information were easy to find though, didnt think I could put 12V into the R pi USB c ? Probaly what it is though.
Thanks again
