08-14-2024, 08:03 PM
I had problem to integrate KC868-32B by MQTT, ethernet webpage loaded up, and i was able to control relays over webpage but it was not listen to MQTT.
Then i decided to try new firmware, but when i upgraded from V446 into V447, ethernet interface webpage disapear, and device is no longer active in the DHCP, it is not getting IP, but ethernet port green is lighting and orange is slowly flashing. I connected box into my WIFI but then i am not able to control relays anyhow. ( I want primary to get MQTT).
Any suggestion how to repair ethernet, and what could be wrong when i just made firmware upgrade / downgrade back doesnt help.
![[Image: Relay-Board.png]](https://i.ibb.co/qW7gfjd/Relay-Board.png)
![[Image: NodeRED.png]](https://i.ibb.co/xqWbpSH/NodeRED.png)
