09-13-2024, 11:46 PM
* Description:
* This Arduino program reads analog values from four analog input pins (A1, A2, A3, A4)
* and prints the values to the Serial Monitor. The analog inputs are defined with specific
* GPIO pins and the program reads the voltage levels from these pins every 2 seconds.
* Pin Definitions:
* - A1: GPIO 7
* - A2: GPIO 6
* - A3: GPIO 5
* - A4: GPIO 4
#define ANALOG_A1 7 // Define GPIO pin for analog input A1
#define ANALOG_A2 6 // Define GPIO pin for analog input A2
#define ANALOG_A3 5 // Define GPIO pin for analog input A3
#define ANALOG_A4 4 // Define GPIO pin for analog input A4
void setup()
Serial.begin(115200); // Initialize serial communication at 115200 baud rate
delay(500); // Short delay to allow serial communication to start
pinMode(ANALOG_A1, INPUT); // Set GPIO 5 as an input for analog signal A1
pinMode(ANALOG_A2, INPUT); // Set GPIO 7 as an input for analog signal A2
pinMode(ANALOG_A3, INPUT); // Set GPIO 6 as an input for analog signal A3
pinMode(ANALOG_A4, INPUT); // Set GPIO 4 as an input for analog signal A4
void loop()
// Read and print analog values from the defined pins
Serial.print("A1=");
Serial.println(analogRead(ANALOG_A1)); // Read and print the value from A1
Serial.print("A2=");
Serial.println(analogRead(ANALOG_A2)); // Read and print the value from A2
Serial.print("A3=");
Serial.println(analogRead(ANALOG_A3)); // Read and print the value from A3
Serial.print("A4=");
Serial.println(analogRead(ANALOG_A4)); // Read and print the value from A4
delay(2000); // Wait for 2 seconds before the next reading
3-analog-input.zip (Size: 768 bytes / Downloads: 678)
3-analog-input.ino.merged.zip (Size: 182.47 KB / Downloads: 654)
