09-13-2024, 11:51 PM
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 1
* - GPIO 2
* - GPIO 38
* - GPIO 0
* - GPIO 21
* Hardware Requirements:
#define GPIO_PIN_1 1
#define GPIO_PIN_2 2
#define GPIO_PIN_38 38
#define GPIO_PIN_0 0
#define GPIO_PIN_21 21
bool prevState[5] = {false, false, false, false, false}; // Adjusted to 5 elements
while (!Serial); // Wait for the serial monitor to open
pinMode(GPIO_PIN_1, INPUT);
pinMode(GPIO_PIN_2, INPUT);
pinMode(GPIO_PIN_38, INPUT);
pinMode(GPIO_PIN_0, INPUT);
pinMode(GPIO_PIN_21, INPUT);
bool currentState[5];
currentState[0] = digitalRead(GPIO_PIN_1);
currentState[1] = digitalRead(GPIO_PIN_2);
currentState[2] = digitalRead(GPIO_PIN_38);
currentState[3] = digitalRead(GPIO_PIN_0);
currentState[4] = digitalRead(GPIO_PIN_21);
for (int i = 0; i < 5; i++) {
Serial.print("GPIO ");
Serial.print(i == 0 ? GPIO_PIN_1 :
i == 1 ? GPIO_PIN_2 :
i == 2 ? GPIO_PIN_38 :
i == 3 ? GPIO_PIN_0 : GPIO_PIN_21);
Serial.print(" changed to ");
// Update the previous state
5-free-gpio-state.zip (Size: 1,011 bytes / Downloads: 708)
5-free-gpio-state.ino.merged.zip (Size: 177.4 KB / Downloads: 703)
